Larry Winger's 601XL Project
Date:  8-31-2014
Number of Hours:  4.25
Brief Description:  Safety wired ailerons and measured deflection
I did my last safety wiring today on the ailerons. There are three turnbuckles in the system, two of which were covered by the aileron control stop which I had to remove. The third tiurnbuckle is up behind the passenger seat in an area that can only be seen with a mirror. What a challenge. I was practically standing on my head to do this work and the wrap was effective but not pretty. Two times I drew blood from the sharp ends of the safety wire, leaving my blood on the field of engagament. I guess today I added blood to the sweat and tears of this project. Finally, I checked the aileron deflection. Plans call for deflection of 11.5 degrees, plus or minus 1 degree. My right aileron is 11.4 degrees both up and down and my left wing is 11.0 degrees both up and down. I"m good to go.
Wiring complete with control stop removed
Leaving it all on the field of engagement
