Brief Description: Split nose bowl inlets and set idle RPM
Using a Fein tool, I was able to split the nose bowl inlet rings. After some sanding away of rough edges, I added small amounts of epoxy and flox to build up areas that were damaged or missing. I rolled out the airplane and set the engine to idle between 750 and 800 RPM.
