My readings were the reverse of what I expected for electrical current and draw, so I reversed the inline sensor. Also, the EGT on clylinder 6 has not been reading properly. I switched it to a different RDAC input, and the input is fine but the EGT sensor is not. Matt will supply replacement. I calibrated both the battery voltage and OAT for the Voyager as well.
