Larry Winger's 601XL Project
Date:  6-3-2014
Number of Hours:  3.75
Brief Description:  Preliminary weight & balance
Before calibrating my fuel tanks, I thought this would be a good time to get a preliminary weight & balance calculation. Because I had taken the plane apart for engine and panel access, I brought back the missing pieces and stacked them at the correct stations. I put the wheel pants on loosely and added the missing door on the bottom of the fuselage. While I will need to do this one more time with everything finally installed and precisely measured, it told me that I have an available payload of 500 lbs. That is workable for me alone with full fuel and lots of baggage. If I want to take up another person over 140 pounds, I'll just need to be carrying less fuel. Not a problem. I also routed the fuel sender wires and made the final connection to the RDAC. I familiarized myself with the fuel calibration routines for my EFIS and then made a call for fuel delivery, only to learn that they were already closed. Just another job for tomorrow.
Parts stacked and ready to get my weight
Nose gear reading
Nose gear reading
