Now that my elevator stops are in place, it is time to re-rig the elevator. With the old cables and hardware removed, I was able to see that the lower turnbuckle on my elevator control arm was slightly bent. I had missed the instruction to file a notch in the arm to prevent binding with the shackle. Getting in there to do the work was no small task after installation. If you have the chance to do so before installation, you should.
