Larry Winger's 601XL Project
Date:  5-23-2014
Number of Hours:  5.00
Brief Description:  Rigged and adjusted rudder
I spent a fair amount of time lining up the nosewheel and rudder to be as straight as possible. In the area under the elevator saddle, I marked the centerline and millimeters on either side. This allowed me to use a long straight edge (1 meter long) and hold it on either side of the rudder to get identical readings. I then used a couple of 1x2 boards and clamped them at both ends, wrapping around the rudder, to keep it in place while I made and fitted the cables. It worked like a charm. Now that the wings are on, working down around the rudder pedals requires circus-level feats of contortion. Aligning the castle nuts on drilled bolts to allow a cotter pin to secure it -- while reaching through in a position I can't even describe -- was the most difficult part of the process, by far. At least it is now in the "completed" column.
Device to immobilize rudder
Measuring on either side of the center line
Another view of my improvised clamp
