Larry Winger's 601XL Project
Date:  12-21-2012
Number of Hours:  3.25
Brief Description:  2 - Installed right wing fairing
Like several other parts on this project, most notably the canopy, mounting of this part is an exercise in placing an object in space. Yes, you have two clearly fixed points -- the outboard attachment bracket nutplates, but after that you are almost on your own to determine alignment in all three axes. By taking it slow and easy, I feel very good about the end result. If past patterns hold true, I should be able to do the other fairing in a little over half the time.
All dressed up and itching to fly
Two outboard screws
Two outboard screws
Inboard trimming and mounting screw
