Larry Winger's 601XL Project
Date:  11-27-2012
Number of Hours:  3.50
Brief Description:  2 - Wired roll trim, added 2nd OAT and misc.
I did quite a variety of jobs tonight, but the two biggest were finishing the wiring on the flap position sensor (power, ground and data to IOEX) and wiring for the roll trim connection (5 conductor wire to wing root). Because I chose to combine the power for the pitch & flap LED indicators as well as the roll trim potentiometer through one fuse, I had to combine all three into one .025" FastOn. Tonight I also connected the data wire from flap, pitch and roll sensors to the IOEX, Analog Inputs 9-11. I also put rubber trim on the remaining sharp edges behind the instrument panel. Finally, I needed to place the OAT sensor for the XTreme EFIS. Borrowing an idea from the Sling LSA, I put the OAT deep in the NACA vent. The 1st picture below gives a peek-a-boo look at the OAT probe. It makes for a short run to the EFIS.
XTreme OAT hiding in NACA air vent
Left side wires
Left side wires
Right side wires
Right side wires
