Larry Winger's 601XL Project
Date:  11-25-2012
Number of Hours:  2.25
Brief Description:  Added panel LED for flap setting
Last week I did research on how to get the flap settings on my EFIS and found that Ray Allen makes a position sensor that you attach to the flap arm. Mine came in just after Thanksgiving so I temporarily hooked it up to an LED display to test the effective range. I've been told that it doesn't read all the way to either end, so I found the effective range and marked it on the position arm. Next I decided that I would like to have my flap position visible at all times, so I cut a new hole in my panel for that LED indicator. Finally I labeled the switches. My plan is to have redundant displays -- both LED and EFIS -- for the pitch & roll trim as well as the flaps. I'm in the process of producing the CAD drawing of that for my wire book.
Flap setting indicator installed
Pitch light active
Pitch light active
