Larry Winger's 601XL Project
Date:  8-4-2012
Number of Hours:  3.75
Brief Description:  2 - Routed elevator trim cable
My first job was to open the access panel on my elevator trim to pull the wires back into the elevator and secure them better. Several years of the weight of the coiled wire hanging from the elevator had worked the wire out through the grommet. I used 3/16" light duty clamps for most of my heavy routing. You'll notice an oversized aluminum washer on top of each clamp. This was just insurance that the rivet head won't work its way through, since it is somewhat smaller than the hole. I elected to route my wire above the H.T. frame and pop out through a grommet in the rear bulkhead. Next I crossed to the left side of the aircraft and routed it from there forward. Fortunately, when routing was complete, I had about 12 inches of cable to spare. I'll take it.
Routing along the rear spar of the horizontal stabilizer
Coming into the fuselage through a grommet in the rear bulkhead
Transition from following the longeron to ducking under the baggage shelf
