Larry Winger's 601XL Project
Date:  7-15-2012
Number of Hours:  1.00
Brief Description:  2 - Connected oil temp and began oil pressure send
I completed the wiring for the oil temp sender to the RDAC. I started the wiring for the oil pressure sender, but was surprised when there was continuity between the gauge wire post and the case of the sender. I'll check with Matt tomorrow. If it is correct, all I need is a hose clamp to clamp the ground wire to the 1.3" diameter sender.
Oil temp sender wired
More wiring of senders
Temporary wiring for oil pressure sender
