Larry Winger's 601XL Project
Date:  6-10-2012
Number of Hours:  1.75
Brief Description:  Re-pitched prop & installed firesleeve
Using the same procedure I described on 9/27/2011, I set the pitch on the prop again. Hopefully this will be the last time before my maiden flight. I also installed the firesleeve on the fuel line from the pumps to the carb.
Firesleeve protection installed
8.5 degrees of pitch
