Brief Description: 1 -Reinstalled control cables into panel
In order to determine cable routing and work around it, I installed the cable control knobs into the panel frame, giving them a full tightening. I am not going to connect the ends to the throttle, mixture control, carb heat or cabin heat until I've completed the panel wiring and know that I won't have to remove it again.
