Larry Winger's 601XL Project
Date:  5-20-2012
Number of Hours:  1.00
Brief Description:  1 -Reinstalled control cables into panel
In order to determine cable routing and work around it, I installed the cable control knobs into the panel frame, giving them a full tightening. I am not going to connect the ends to the throttle, mixture control, carb heat or cabin heat until I've completed the panel wiring and know that I won't have to remove it again.
Control knobs tightened in place
Routing behind
Routing behind
