Brief Description: Installed battery and master solenoid relay
Installed the battery box using AN3 bolts and the relay with AN4 hardware. To prevent rubbing and movement between the metal box and battery, I wrapped the front and sides with leftover rubber baffle seal. This produced a nice, tight fit with no movement.
