Larry Winger's 601XL Project
Date:  10-15-2011
Number of Hours:  2.50
Brief Description:  Installed ELT and panel switches
I spent some time reading through the instructions for the ELT before deciding on the placement for both the antenna and ELT. It was tough drilling a hole in my rear top skin for that antenna. After spending months building a fuselage without extra holes, I'm now in the phase where I'll be going the other direction for antennas and sensors. My order finally arrived for the rest of my panel switches and switch covers, so I completed their installation. The only holes in the panel are for carb heat, throttle, mixture control and cabin heat (far right under the transponder).
ELT antenna in place
ELT placement on right side just ahead of the bottom opening
All switches in place
