Brief Description: 1 - Transponder frame secured and panel primed
The reason I put a #1 in front of the subject line is to keep my entries today in order. Otherwise it goes in alpha order, which would likely have me applying the final coat of paint before my primer. Not a good idea. I used the Rust-oleum Stops Rust Clean Metal Primer 7780830 and will finish it with Rust-oleum Metallic Charcoal 244228.
