When it was time to layout the panel, I needed to maximize space for the Voyager, transponder and audio panel. The overall footprint of the map box was slightly too big, so I elected to cut a part of the upper right corner to make it work. The only visual ramification is the door which had to be trimmed to fit in the tight corner. I'm going to liive with the asymmetry before deciding whether or not to make the two top corners match. I just need to install the camloc in the top center and I'm read to rivet the whole box / bracing in place.
