Brief Description: Removed center spar and separated it
This was a very straightforward task tonight. The only thing that made thiings go slower was the fact that I pulled the rivets on the bottom front flange from the bottom of the fuselage (easy to remove), but the bottom rear flange I pulled from inside, which meant I had to do some contortions to drill out the rivet heads.
