Jeff's RV9A Build
Date:  10-2-2017
Number of Hours:  4.00
Brief Description:  Rivet aft Spars to Doubler, Rivet Hinge Brackets t
Counter sunk the required holes on the forward side of HS906 doubler, Aft side of 903 aft spar. Riveted the doubler to the two aft spars and riveted the HS912 hinge brackets to the spars.
Rivet Aft Spar to Doubler
Rivet AftSpar to Doubler
Attach Hinge Brackets
