Jeff's RV9A Build
Date:  7-16-2017
Number of Hours:  3.00
Brief Description:  Cutting out HS908 L & R Attach Angles
Used the old band saw that my Dad had given me to cut out the HS908 left and right attach angles out of the 6061T6 Aluminum angle stock. I made sure to stay out side of the cut lines. I plan on using my die grinder and sandpaper and 3m discs to sand it down to the correct size. You can see in the rough cut image I did not leave much but it still took considerable time to sand and polish the angle down to size. I only finished HS908 left today. I will have to start on the right attach angle tomorrow.
Cutting HS908 L&R
Cutting HS908 L&R
HS908 L&R rough cut
HS908 L&R rough cut
HS908 Left
HS908 Left
