Jon Burns - Zodiac 601 XL
Date: 6-2-2007
Number of Hours: 14.00
Brief Description: Left Wing
It was nice to have most of the work already complete for the lest wing. The skeleton, and the Landing Light Option assembly were done earlier with the assembly of the right wing.
I completed the top and bottom skins, installed the tie down bracket, ran conduit, installed the lighting and strobe cables in the conduit, and built the wing locker. I measured and fit the nose skin as well, but it is only in with silver clecos. I still have some work to do on the LLO lense cutout.
I cut the access hole for the pitot assembly, but did not install it since I do not want to knock it off. I may run the 1/4 in tubing in the top inside of the wing locker to get it out the wing root.
The wing locker is much nicer than the one in the right wing, and only took a fraction of the time it took to do the other unit. I used the blade to score the skin and used the cut out piece to make the lid. This saved a lot of time, since last time, I had to file and file to make the lid as close as possible to the opening.
