Brief Description: Fit the pitot and aileron push/pull rod
To get the correct length for the aileron push/pull tube I hung a string down the side of the wing and lined up all the tooling holes witch is the center line of the wing, that put the aileron in the neutral position then I jigged the aileron bellcrank in the neutral position and measured how long the tube needed to be. I also fit the pitot mount to day.
