Where are those new plans I ordered? I marked the w-306e spar doubler plate per the plans, drilled the holes, placed it on the w-306a rear spar drilled, positioned the w-322L aileron bracket drilled, no brainier right? WRONG the holes on the w-322L are to close to the radius... called vans AGAIN for some more new parts. New plans showed up Monday see the difference
