RV-3
RV-3
Assemble rudder spar
I ended up using flush rivets in the corner of the bottom rudder rib under the rudder horn. If you modify the rudder horn slightly from the plans you can ovoid doing this. This is another spot where the plans are wrong.
RV-3 Home
RV-3 Home
