Drew the VS-307 and cut it out on the band saw. You have to be careful here, the plans assumes you know the Dimension of the f-311 and the tail spring mount. If you do not have the fuselage parts just remember that the tail spring mount bolts on threw the bottom rudder bearing bracket.
