Pauls Web Site
Date:  7-17-2011
Number of Hours:  1.50
Brief Description:  Drilled Piano Hinge
To drill the pilot holes in the piano hinge I used Sonex's suggestion of using a metal ruler as a template. I found that it is important to only use about 6 inches of the ruler because the hinge spacing isn't exactly 1", or the rulers I bought aren't. Moving the section of ruler along the hinge and clecoing in place worked well.
