Pauls Web Site
Date:  6-25-2015
Number of Hours:  15.00
Manual Reference:  F06-F07-F08
Brief Description:  Trim Lever and Glaresheild Fit
With the fuselage upside down, I fabricated the seat, then installed it. Seeing that it fit fine, but would be in the way, I removed it for now
I then installed the trim lever, and then flipped the fuselage over so it's right side up again.
Cut the glareshild to size from Sonex supplied pre-bent form, and drilled the holes that will match up to the instrument panel.
Fabricating Seat
Fabricating Seat
Upside Down Trim Lever
Fitting Glareshild
Fitting Glareshild
