Pauls Web Site
Sonex
F06-F07-F08
Trim Lever and Glaresheild Fit
With the fuselage upside down, I fabricated the seat, then installed it. Seeing that it fit fine, but would be in the way, I removed it for now
I then installed the trim lever, and then flipped the fuselage over so it's right side up again.
Cut the glareshild to size from Sonex supplied pre-bent form, and drilled the holes that will match up to the instrument panel.
Fabricating Seat
Upside Down Trim Lever
Fitting Glareshild
Sonex Home
907
Brakes
Carburator
Flying
Fuel Systerm
Lights
Moving
Tail
53
178
