Next on the agenda was the installation of the wing tip. It was a tight fit and the supplied parts were made to fit fairly well except for a gap that appeared from the leading edge down and to the spar. This meant if left alone, there would not be any connection between the skin and the bottom wing tip panel and something needed to be done.
My approach was to create a cover (if it can be called that) that connected the two pieces. I'm sure that same type of approach could be done using tabs mounted on the inside but that would take too much time and would only look better. :)
