Waiting to hear from the factory on the fitment issue I have with the "C" bulkhead, I opted to move ahead and fit/install the VS skin. Ahh, but grasshopper, nothing shall be easy if there are other options. It was clear that there was zero chance the holes would all line up. The forward spar clearly will not due to a hole spacing issue on each end and the bottom, rear rivet holes just can't work due to a SED issue. Me thinks it might be a modeling issue but after "filing to fit" the forward, lower section of the skin it ended up fitting fine, I just won't be able to use the factory holes in the skin. I'm betting that even if they aren't filled, only the sharpest of eyes will see them and since they are evenly spaced and there are several of them, they're going to look like they belong there. :)
