Darrel's Kitfox - SS7
DEW2
Contour rib profil
Contoured rib profile and more work on tip
Sanded out the "hump" set up by the leading edge of the main ribs using the template that came in the kit.
Began filling in the low spots on the wing (i.e., gap between fuel tank and spar and leading edge and spar) with Super Fill.
While waiting for the first mix to set up, worked a bit more on fitting the wing tip on the right wing.
The hump
After sanding
Super FIll in action
DEW2 Home
2340
Basic Kit
93
Fabric cover
82
293
Final assembly
501
Inspection
Kitfox Avionics
Kitfox tooling
Kitfox Undercarriage
Kitfox wings
Lighting
88
Paint System
87
335
Tooling
Tooling
