Brief Description: Painted stripe on upper cowl and spinner
Applied bondo to the intersection of the individual struts where they join at the fuselage.
Painted the strip on the upper cowl and the spinner. (The drying time between the 6 fog coats and one wet coat was excessively long due to high humidity.)
Found another opportunity to zip tie two more lines together on the engine and did so.
