Got up early to a light drizzle. Thought I'd give risk it all and spray the fuselage with a coat of primer. I knew I was violating the manufacturer's environmental limits but for primer the risk of creating a problem was less than color coats and, after all, high humidity is forecasted for several coming days. Anyhow, it did go fairly well except for two areas that will need quite a bit of sanding and I wasn't able to lay down a smooth final coat so a light sanding job is needed for the entire fuse - but that isn't much more that would be need prior to spraying the color coat so all is not so bad after all. That’s my story and I’m sticking to it.
