Brief Description: Prepped for EkoBond and finished sanding
Finished sanding the wing panel. Found one spot, about 1 inch in diameter, in which the paint lifted. Called the paint factory and determined a rework process that appears to have done the trick.
Prepped the fuselage (cleaned and washed) for EkoBond.
