Brief Description: Sprayed 2 cross coats of UV primer
After talking to Andy at Stewart Systems, changed the primer coating process just a bit. Now will use a 1.2 mm nozzle, a tad more gun pressure (25 psi, up 3 pounds) and apply two cross coats as step 1. (Then iron down the pinked edges – step 2 - and sand – step 3; then spray the 3rd coat as step 4.)
