Darrel's Kitfox - SS7
Date:  9-8-2018
Number of Hours:  6.00
Brief Description:  Wing install and begin jigging
Today was a really big day - we installed the wings for the first time and began the jigging process.
We used four one inch blocks taped in position at each end of the forward spars and pulled a string in front of then to ensure both wing panels were true to each other. Lesson - read and check off each and every line of the manual or you to will have to demount each wing panel and install the number one rib like it says to do.
They are on
They are on
I only look confused
