Darrel's Kitfox - SS7
Date:  4-24-2020
Number of Hours:  4.10
Manual Reference:  None
Brief Description:  Decals and glare shield
Installed "Experimental" and "N" number decals.
Discovered that you can put polyester resin (bondo) on some paints, like the one I used on the glare shield, and if you do, it gets gummy and it all has to be removed.
Almost completed fabrication of the flaperon holding fixture that will be used to set its alignment.
