Darrel's Kitfox - SS7
Date:  11-13-2019
Number of Hours:  7.20
Manual Reference:  Engine Install
Brief Description:  Bolt clearance improved, water pump housing replac
Tested the wing bolt/pin installation access through the holes put in the canopy yesterday and decided to open them a bit to absolutely assure they would go in and out with zero chance of contacting the windshield.
Removed engine and replaced the water pump housing. Note: had to remove some flash on the molded aluminum parts that interfered with mounting the housing. It was possible to install the housing without the removal if you have a clear view but if the housing ever needs to be removed in situ then all bets would have been off.
Laid up 2 plies of glass which will be an addition to the top cowl and close the opening (gap) between the cowl and windshield
First layer
First layer
Second layer
Second layer
With peel ply
With peel ply
