Darrel's Kitfox - SS7
Date:  1-9-2019
Number of Hours:  5.70
Manual Reference:  Control setting up
Brief Description:  Continued setting control stops
Set up the elevator up and down control stops.
Torqued all jam nuts and applied proof lacquer.
Removed the HT and elevator.
Installed the communication di-pole antenna.
Rerouted the trim drive motor wiring - moved to a port fuselage position to better avoid control linkages and antennas that may cause some level of interference between the wiring.
Measuring elevator top range
Comm antenna top end
Comm antenna bottom end rough
