Darrel's Kitfox - SS7
Date:  12-23-2018
Number of Hours:  2.50
Manual Reference:  Instrument Panel
Brief Description:  Installed tilt feature for instrument panel
Carved out some fun time today to put in the instrument panel hinges. The hinge pieces rivet to the frame and to the panel but retain the original bolt attachment as well. Before final install, I'll add a 0.100in piece of rubber between the hinge pieces as a form of vibration isolator - maybe it is meaningful and maybe it isn't. We'll see. If all fails it is a simple matter to remove the hinges and revert to the original design.
Hinges riveted to the frame
The wood piece will be replaced with rubber
Now it tilts
Now it tilts
