Darrel's Kitfox - SS7
Date:  6-17-2018
Number of Hours:  4.50
Manual Reference:  Window install
Brief Description:  Window and door install
Completed the port rear window frame install - made an error - didn't plan for the proper overlap in frame material between the forward window frame and the rear door window frame.
After lots of study I'm beginning to believe this might be an error with an unplanned benefit. If they were left to join where they naturally would the meeting place is pretty far out from the side of the fuselage and would cause problems with covering.
Also, bent the lower frame of the door to match a bend in the corresponding rail in the fuselage.
