Brief Description: Continued installing the rudder cables
Installed the cables and all came out acceptable IAW 43-13b but I'm not pleased with the crimps and finished connections at the pedal ends of the cables and I'll be redoing them after practicing a bit. Turns out that the nicopress sleeves elongate more than I allowed for and pushed the cable up too hard against the AN111 cable fitting and put a hard bend in the cable. I also learned how to form the cable around the fitting without separating any of the strands but that lesson cost a fitting assemble. So, all will be done again - I think this learning process is one of the sources of "experiment" in experimental.
