Darrel's Kitfox - SS7
Date:  5-4-2018
Number of Hours:  4.50
Manual Reference:  Fuselage
Brief Description:  Cont'd assembling control linkage components
Completed assembly of flap handle (installed internal components) This required making a jig to center drill a 0.250 solid rod while ensuring it matched the supplied flap slider and, then, while holding all in place, press fit a roll pin.
Since the bearing lock (adhesive) came in, also installed the bearings in the control column.
Test fit/installed the flap handle assembly in the fuselage weldment. There may be an issue here, more to follow.
Cleaned and prepared the aluminum prep tanks (alodine system) for use tomorrow.
Drilling flap restaining pin
