Brief Description: Fitted the prop flange to the hub
Spent most of the day openning up the mounting holes in the hub to get it to go on the prop flange properly. Once done, discovered the the spinner mounting holes weren't clocked correctly. A new mounting flange is on its way.
Put the tail on the tail stand to check for correct height. Was pretty close but have to cut off a bit - mostly due to the slope of the floor which I hadn't accounted for.
