Brief Description: Final oil cooling line, manifold pressure install
Cut to length an installed the last oil line. Had to reposition the Adel clamp on its mount to pick up needed clearance from the side of the lower cowling.
Fabricated and installed the manifold vacuum line.
Installed the propeller for a fit and alignment check.
Cut the oil cooler air intake hole in the lower cowl.
