Brief Description: Fabricate exhaust pipe close outs
Remade one of the baffle mounting tabs - all of the cut and fit activity revealed a better design and that is what I went for.
Fabricated two small plates that close off the exhaust pipe pass thru holes. As admitted earlier, I getting the holes exactly where you would like them is neigh onto impossible so they end up being larger than desired - plus - the manual calls for holes larger than needed. So, I am closing them off and to a small size.
Took the muffler and number 4 exhaust pipe to a welder to have the new spring mounting tabs put on.
Cut, via a series of trial and error, the baffle to fit the lower cowl.
