Brief Description: Bolt clearance improved, water pump housing replac
Tested the wing bolt/pin installation access through the holes put in the canopy yesterday and decided to open them a bit to absolutely assure they would go in and out with zero chance of contacting the windshield.
Removed engine and replaced the water pump housing. Note: had to remove some flash on the molded aluminum parts that interfered with mounting the housing. It was possible to install the housing without the removal if you have a clear view but if the housing ever needs to be removed in situ then all bets would have been off.
Laid up 2 plies of glass which will be an addition to the top cowl and close the opening (gap) between the cowl and windshield
