Darrel's Kitfox - SS7
Date:  2-15-2019
Number of Hours:  3.50
Manual Reference:  Final assembly
Brief Description:  Fabricated and installed nut plates
Rolled on first coat of white primer on paint test panel.
Removed the HS.
Threaded mounting holes for PK screws.
Fabricated nut plates for the small (rear) part of the inspection panel.
Fabricated and installed mounting tabs for the ones that had to be removed (due to interferring with the large inspection panel).
Nut(s) plate
Nut(s) plate
Replacement tab
Replacement tab
Small rear plate installed
