Darrel's Kitfox - SS7
Date:  1-23-2019
Number of Hours:  1.10
Manual Reference:  Instrument Panel
Brief Description:  Continued cutting instrument panel
Continued fitting components in the instrument panel. Today was a bit tedious as it involved locating and drilling the mounting holes for the round instruments. A personal challenge is to not have to over enlarge the screw holes to get all of them in. Also, spent a lot of time (probably needlessly) shortening tabs onf the fuse block after I discovered that they could be used, in addition to the standoffs I plan on using, to hold proper position behind the panel.
As a side (calendar) note; spent time installing the compressed air drying labyrinth.
